Electrical query
Hammerite
Main scooter: Sx150
I've put a 12v loom into a VBA with all the necessary ancillary bits and all is well apart from the horn .... When you press the cut out button the horn sounds . It still cuts out though . According to the wiring diagram the horn wire is in the correct terminal in the switch
Thanks
Rich
eden
sounds like you have the live and earth the wrong way round on the horn as its getting the power from the ignition going to earth when its turned off. Maybe lol
