Two Stage Boysen Reeds vs standard TS1 Yamaha reeds
Posted: Mon Apr 25, 2016 12:44 pm
Got a TS1 stripped down to replace a drive side oil seal ready for Euro and to see if anything else needs upgrading. Existing Yamaha reeds look to be perfect, but with everything stripped down, I have the opportunity to upgrade to the 2 stage Boysen reeds.
The cost part is not the issue, the issue is that the TS1 runs OK, so why change something that's already working. I can see how the 2 sets of petals will open over the rev range to provide a better response. However, has anyone else done this upgrade and noticed a substantial difference in pulling power or whatever.
Plus, if fitting Boysen 2 stage reeds, would you recommend keeping the steel back stop in place.
Thanks
Thanks
