Page 1 of 3
Vapor speedo
Posted: Sat Apr 23, 2016 10:52 pm
by philtrate
I've recently changed from ac to dc and fitted a new vapor Speedo my question is with the rpm wire, when it's rapped around the ht lead the bar rpm graph goes up to 12000 revs at about 30/40 mph and is very irratic, can the the wire be joined to one of the yellow wires from the stator plate to calm it down
Re: Vapor speedo
Posted: Sun Apr 24, 2016 3:48 pm
by Meds
I have been thinking about one of these.
According to the manual (for a motorcycle ) you can connect it directly into the low voltage coil supply, which will pulse every time you get a spark. (ie green wire in the head set on a lambretta)
I would be interested as to how this works out, my issue 2 issues are
fitting the speedo to a scoot RS outboard disk.
Mounting it.
Re: Vapor speedo
Posted: Sun Apr 24, 2016 5:43 pm
by philtrate
Hi meds, when I bought my first vapor it came from mbdevelopments with there own bracket which fits on the axle on the left hand side for the sensor, the vapor itself is fitted in the headset itself
Re: Vapor speedo
Posted: Sun Apr 24, 2016 6:41 pm
by Meds
Thanks
Did you check up their website for fitting the RPM sensor.
http://www.trailtechproducts.co.uk/acat ... ELV-07.pdf
What I couldn't find was size pulse it needs.
Re: Vapor speedo
Posted: Fri Apr 29, 2016 9:35 pm
by corrado
I have some Indian GP headset tops modified to accept the Vapor units. £65.
Re: Vapor speedo
Posted: Fri Apr 29, 2016 9:44 pm
by jonzo172
RPM Sensor just wraps around the HT lead as per instruction.
Re: Vapor speedo
Posted: Sat Apr 30, 2016 12:56 pm
by Meds
Thanks Corrado, but I I need an LIS type top.
Hi Jonzo172, if you follow the link I posted, RPM sensor fitting option 2 is using the LT coil supply, which is a neat solution but not sure if it will work on a Lambretta
Did you sort your problem philtrate?
Fitting the speedo sensor isn't a simple job I would like to drill,and tap a hole to fit the speedo sensor into the calliper holding pate and use one of the disk bolts for the magnet or fit it too the rear shock mounting block in the back wheel.
Either way a neat solution will take a bit of effort and I'm enjoying riding at the moment.
Re: Vapor speedo
Posted: Sat Apr 30, 2016 11:35 pm
by Muttley McLadd
Can't you wrap it around the HT lead and hold it on with a bit of black tape? It's practically invisible, even with the panel off.
You can get natty little alloy holders for Vapors, that can be bolted onto anywhere you want. I put mine at the top of the legshields, but you can bolt them to the top of a toolbox, if it's not a Rally type (the door gets in the way).
Legshield mounted:
Re: Vapor speedo
Posted: Sun May 01, 2016 1:22 pm
by philtrate
I have the rpm wire on the ht lead anyway and it was fine when on ac but now its wassel dc it just goes bonkers at lowish speeds
Re: Vapor speedo
Posted: Sun May 01, 2016 3:35 pm
by Trojan
I m thinking of getting one of these Vapor s....wondered which type do I need to order/Model?? and are they a complete kit or do you have to get the sensors and magnets separate....thanks in advance.....
