Toolbox Trim
Posted: Fri Apr 22, 2016 8:47 pm
by Doom Patrol
I have a legshield toolbox and the door rattles. Ideally I think it needs a bit of trim around the lip to prevent vibration. What have people used to solve the problem?
Re: Toolbox Trim
Posted: Fri Apr 22, 2016 8:55 pm
by bristolmod
shouldn't need any - bend the inner lock bit.
Re: Toolbox Trim
Posted: Fri Apr 22, 2016 9:04 pm
by Doom Patrol
I might have too.
Re: Toolbox Trim
Posted: Fri Apr 22, 2016 11:27 pm
by wack 63
Fit Vespa toolbox buffers in the top corners
Re: Toolbox Trim
Posted: Sat Apr 23, 2016 11:42 am
by Norrie Bodge
Doom Patrol wrote:I have a legshield toolbox and the door rattles. Ideally I think it needs a bit of trim around the lip to prevent vibration. What have people used to solve the problem?
I did exactly as you thinking...
Got some door trim from Beedspeed, give them a buzz m8
Re: Toolbox Trim
Posted: Sat Apr 23, 2016 3:53 pm
by shocky
Sent from my SM-G903F using Tapatalk
Re: Toolbox Trim
Posted: Sat Apr 23, 2016 3:59 pm
by Shipleystevep
Jam a bit of cardboard in it
Re: Toolbox Trim
Posted: Mon Apr 25, 2016 7:59 am
by Minority
Four little rubber buffers from the local hardware store, drilled and bolted one in each corner, Bob's your uncle!
(Guess it depends on what type of toolbox you have)
Re: Toolbox Trim
Posted: Mon Apr 25, 2016 9:50 pm
by Doom Patrol
That's a good idea. Unfortunately it isn't one of them. Bristolmod seems to have come up trumps at the moment. A bit of jiggling of the lock seems to have tightened it up.
Re: Toolbox Trim
Posted: Tue Apr 26, 2016 7:46 pm
by gaz_powell
this is what I use on frame/toolbox door and legshield toolbox door
http://www.ebay.co.uk/itm/201481150392? ... EBIDX%3AIT
