oil leak
Posted: Wed Apr 20, 2016 9:23 pm
by duc748
been out and about,running in scoot(225 kit),it is leaking oil all over the back wheel,have checked the sump plug,ok,oil seemed to be coming from one off the chain case bolts,tight end that up(it did tighten up slightly),any other ideas?
duc748
Re: oil leak
Posted: Wed Apr 20, 2016 9:38 pm
by warts
Over filled gearbox/breather blocked?
Ripped gasket? Damaged gasket face?
Something fouling and not allowing proper joint contact?
DS oil seal leak? A leak down test required?
Re: oil leak
by Muppet
O ring on the gear selector rod?
Re: oil leak
Posted: Wed Apr 20, 2016 9:39 pm
by lambro
'O' ring on the selector shaft.
Re: oil leak
Posted: Thu Apr 21, 2016 4:51 am
by duc748
how do i find if breather blocked?
Re: oil leak
Posted: Thu Apr 21, 2016 6:35 am
by warts
Give it a rinse, dry off and see if you can blow through it.
Double check for over filling first. Carefully clean all the leaked oil off. Remove breather. Shove a bit of tissue lightly in the hole to stop any splashing. Go for a run round the block.
Re: oil leak
Posted: Thu Apr 21, 2016 6:47 am
by mick1
could be oil from the exhaust if you're running too rich.
"o" ring on the selector arm is always a good one as been said.
