GT240 Build
GeorgeS
This is the 70mm prototype, larger than the gt200 which I think is 66mm.
Sent from my SM-G920F using Tapatalk
GeorgeS
Plus Rich_T has had a lot of other big projects on this year as well as producing this new part!
garry inglis
how mutch was that one and what power difference are you expecting has he allterd port layout
GeorgeS
Probably best for Richard to answer these questions as I've nothing to compare it to.
I'm just expecting it to be faster than my standard series 2 Li150!
garry inglis
ive just seen it on facebook sent him message
Rich_T
Main scooter: Li Special
GT200 in straight bolt on format is 19 with a good clubman and 24 with a good expansion. The GT240 is likely to be low 20's with clubman and high 20's with expansion. I'm expecting something like 21 or 22 with a clubman and 26-27 with expansion. There are 4 builds going on and two of those have the potential to hit the dyno very soon so the guessing will stop at that point.
To develop this kit it was not as easy as boring out a standard cylinder. There was quite a complicated tooling change to the barrel, all new machining programs (everything is different to previous kits) and the piston required some precise modifications. All in all, it was quite a mission about a year long development.
GeorgeS
Port timings on this 70mm version are similar to the GT200 from my basic readings:
Exhaust: 182
Transfer: 134 (both sides even)
Blowdown: 23
Stator and regulator arrived from Anthony Tambs over the weekend & hopefully the last few bits should come during this week coming so my excitement level is rising. Rich_T says that of the other 3 builds of this kit he's now ridden one & is very pleased with the performance.
If my leak test goes ok it could be running before Christmas.
Muppet
134 is a big number :shock:
C’est la vie
hendy
Muppet wrote:134 is a big number :shock:
Aye, I was thinking much the same
GeorgeS
The 62 stroke increases the duration, this would be around the 126 mark on a standard 58 (I think!).
    Users browsing this forum: Google [Bot] and 27 guests
