new cases
Posted: Wed Apr 13, 2016 3:59 pm
by a.lo.v2
getting exited with all these new casings being casted, but thinking, as you do, does anybody see any problems without having "matching" endplates?. what exactly are the two surfaces that are machined together? is it the cluster or the layshaft? or is it a case of anything will work with correct shimming? a lot of questions i know.
Re: new cases
Posted: Wed Apr 13, 2016 4:16 pm
by shocky
It's the layshaft holes
Re: new cases
Posted: Thu Apr 14, 2016 5:53 am
by warts
Modern CNC machining can ensure sufficient, repeatable, accuracy that "line boring" as in the old days is not required
Re: new cases
Posted: Thu Apr 14, 2016 7:22 am
by ArmandTanzarian
warts wrote:Modern CNC machining can ensure sufficient, repeatable, accuracy that "line boring" as in the old days is not required
That only helps if both bits are made on modern machines. Do the new cases come with endplates or do they use the wibbly wobbly old ones?
Re: new cases
Posted: Thu Apr 14, 2016 8:59 am
by warts
You are absolutely right. Who would cut corners like that?
I wasn't thinking.
Re: new cases
Posted: Thu Apr 14, 2016 12:00 pm
by EddieStone
warts wrote:You are absolutely right. Who would cut corners like that?
SIL?
