Page 1 of 2
Which dremmel?
Posted: Sun Apr 10, 2016 8:58 pm
by alanscottj
Which is the best Dremmel to buy for doing the grinding, cutting and other fettling required with Lambretta parts? Mine has bitten the bullet and needs replacing but I can't find the same model again. What are you using? Tia
Re: Which dremmel?
Posted: Sun Apr 10, 2016 10:30 pm
by Doom Patrol
What model were you using? I suspect they might have discontinued the cordless version. I picked one up cheap quite recently.
Re: Which dremmel?
Posted: Sun Apr 10, 2016 10:38 pm
by 10 inch Terror
I use a Black & Decker one. I've had it 5 years and it's still going strong. The attachments are readily available from B&Q, Screwfix etc etc.
Re: Which dremmel?
Posted: Sun Apr 10, 2016 10:49 pm
by alanscottj
Doom Patrol wrote:What model were you using? I suspect they might have discontinued the cordless version. I picked one up cheap quite recently.
395 mate. Not sure which one to get, the 3000 or 4000, just want to make sure the one I get is powerful enough.
Re: Which dremmel?
Posted: Sun Apr 10, 2016 11:00 pm
by Monty
I use the big boys dremmel a 5 inch angle grinder with a flap wheel. I spend more time changing cutting wheels or burs with a dremmel
Re: Which dremmel?
Posted: Mon Apr 11, 2016 12:20 am
by bazza3004
found the 3000 more than enough for my needs. cutting porting etc.
Re: Which dremmel?
Posted: Mon Apr 11, 2016 8:07 am
by Strummer10
I've got a dremel but when you depress the button to unlock the attachment your using it just turns so I can't get my bits out the end. Is there another Dremel with this button enhanced so it works better or is mine an isolated problem ?
Re: Which dremmel?
Posted: Mon Apr 11, 2016 8:54 am
by Tractorman
bazza3004 wrote:found the 3000 more than enough for my needs. cutting porting etc.
Agree, could not manage without mine now.
Re: Which dremmel?
Posted: Mon Apr 11, 2016 10:51 am
by Meds
I use a normal drill with a flexible drive.
Re: Which dremmel?
Posted: Mon Apr 11, 2016 12:49 pm
by dansacred
