Kheper with Wassell?
KCB
Hello,
Simply that, can you use a Kheper CDI with a Wassel rectifier without any issues?
Thanks.
eden
Yes I have done so for the last 3 years
vegansydney
It's a winning combo! No problems for me after 2+ years.
eden
As the kheper and the wassel are unrelated there is no reason for one not to work with the other.
The wassel is connected to the lighting coils on the stator and the kheper is connected to the pick up and low tension coil on the stator.
KCB
Just thought I'd check as the earthing arrangement has to be changed to use the Wassell :D
