Page 1 of 2
Chain alignment
Posted: Mon Apr 04, 2016 8:46 pm
by Jonn
Does anyone bother with chain alignment ? Im 1mm out approx. Cant find a spanish oil thrower to fit under front sprocket,would washer from under crown wheel be ok?
Re: Chain alignment
Posted: Mon Apr 04, 2016 8:58 pm
by rosscla
Can't you get a thinner shim for the rear sprocket?
Re: Chain alignment
Posted: Mon Apr 04, 2016 9:23 pm
by Jonn
No I have an iwis chain with bigger rivets and this has fouled the endplate previously.Need the iwis for performance engine.
Re: Chain alignment
Posted: Mon Apr 04, 2016 9:36 pm
by Muppet
fit two thrower washers reshim rear sprocket
Re: Chain alignment
Posted: Mon Apr 04, 2016 10:10 pm
by barnsleybilly
Try mb developments, they sell different thickness oil throwers.
Re: Chain alignment
Posted: Mon Apr 04, 2016 10:37 pm
by Knowledge
Jonn wrote:Does anyone bother with chain alignment?
Does anyone? Apparently so, but is it worth it?
Re: Chain alignment
Posted: Tue Apr 05, 2016 4:54 pm
by Jonn
Its the usual Lammanoia...Lambretta Paranoia :D
Re: Chain alignment
Posted: Wed Apr 06, 2016 2:10 pm
by shocky
I always do .I first set the the crown wheel and clutch as low as it will go to get the 0.10mm clearance that is needed with the thinnest shim available this also makes the clutch sit lower and reduces the risk of the kick-start touching the top plate on the clutch I then measure the height at 6 equal intervals on the rear sprocket and find an average then I fit the front and measure again using through same method I'll then look at how thick the throw washer is and compensate. but normally it's not enough so I just lap the drive sprocket sleeve down to the correct height
Re: Chain alignment
Posted: Wed Apr 06, 2016 2:15 pm
by shocky
I believeit reduces the amount of metal in the oil which can cause driveside seal failure
If all it does is help you belive you have put your engine together in the best possible way then it has to be worth it ,why spend 300 on a crank 500 on a kit 400 on a clutch and not do it ? I'm sure ever dealer does it don't they. ..
Re: Chain alignment
Posted: Wed Apr 06, 2016 8:35 pm
by Tractorman
I suppose the main problem is finding a base to measure both sprockets accurately.
