Grrr! Lambrettas.
Posted: Thu Mar 31, 2016 10:12 pm
by philz
Put brake light bulb in and I fired it up all good. Removed headset top replaced blown speedo bulb and It kicks up fires and stalls. Cleaned carb and still the same. The puzzle begins......
Re: Grrr! Lambrettas.
Posted: Thu Mar 31, 2016 10:50 pm
by lambro
Dis-lodged wire on the ignition circuit in the headset at a guess.
Isolate the green from loom at the coil/cdi end and try to start it again, if it starts fault is in the loom/headset.
Posted: Fri Apr 01, 2016 8:41 am
by philz
Thanks will try it Lambro but guessing it wouldn't start at all if that was the problem.
Posted: Fri Apr 01, 2016 12:58 pm
by sean brady scooters
your speedo bulb holder is shorting out on one of the green ignition wires in the head set ,they are very close to each other !
Posted: Fri Apr 01, 2016 3:23 pm
by philz
Thanks Shaun after a couple of hours checking found wires broken on the back of the ignition switch. Easily overlooked due to the rubber cover. Now replaced and running. Thanks for the advice.
Posted: Fri Apr 01, 2016 7:01 pm
by coaster
philz wrote:Thanks Shaun after a couple of hours checking found wires broken on the back of the ignition switch. Easily overlooked due to the rubber cover. Now replaced and running. Thanks for the advice.
Unless one of the broken wires was touching earth and was the one that goes to the CDI, it is likely that the fault is still there and waiting to happen again
What sort of ignition switch is it btw, Indian ones are notoriously prone to developing internal shorts.
Posted: Fri Apr 01, 2016 10:53 pm
by philz
It was Indian. Swapped it out and all is running so it could have been a combo of the broken wires and something else. Will have to wait to see if it re surfaces but hopefully sorted.
Edit:Thinking about it one of the broken wires was red and touching the ignition back so that would be the short coaster.
