Page 1 of 2
Standard TV200 performance tweaks?
Posted: Thu Mar 31, 2016 9:23 pm
by eadmr04
My mates got a standard TV200 and was wondering if there's any simple carb/exhaust tweaks which might give any benefits without going down the route of fitting a kit or anything, want to really maximise the TV's performance whilst keeping it mainly standard. Anyone out there using a 42mm clubman and slightly bigger carb option or something similar? Cheers.
Re: Standard TV200 performance tweaks?
Posted: Fri Apr 01, 2016 12:37 am
by Doom Patrol
Yes. I run a Sito Ancillotti clubman and a Scootopia 22mm carb. Other than that it's pretty much standard with the exception of a GP crank. Goes well.
Posted: Fri Apr 01, 2016 9:27 am
by rosscla
Doom Patrol wrote:Yes. I run a Sito Ancillotti clubman and a Scootopia 22mm carb. Other than that it's pretty much standard with the exception of a GP crank. Goes well.
I'm guessing that GP crank also goes with electronic ignition? Standard weight flywheel?
Posted: Fri Apr 01, 2016 9:43 am
by eadmr04
Have you opened up the air box or any other alterations, everything else standard gearing wise etc? Thanks.
Posted: Fri Apr 01, 2016 1:02 pm
by dave wheeler
tv175, 24 phbl though a baffleless airbox, sito ancillotti, electronic, oh and a cyclone 5 speed, goes great, tops out around 65, cruises at 55-60 and returns 55mpg
Posted: Fri Apr 01, 2016 2:10 pm
by eibarlad
Be careful tweaking this set up if it still has the tall gearbox in it. The TV 200 , especially with the first version 'ring breaker barrel is a great ride left standard.
I'm running one with a good piston so it doesn't spew the rings out, all ports polished & matched to the standard carb - exhaust. Standard air box , Indian electronic with a machined/lighter flywheel.
This motor is adifferent animal to the other innocenti 200's.
Posted: Fri Apr 01, 2016 2:25 pm
by bristolmod
eibarlad wrote:Be careful tweaking this set up if it still has the tall gearbox in it. The TV 200 , especially with the first version 'ring breaker barrel is a great ride left standard.
+1
Posted: Fri Apr 01, 2016 2:57 pm
by EddieStone
It sounds as if you just want bolt on goodies, but if you fancy dismantling it, I would blueprint it - match the ports and manifolds and polish the inlet and exhaust ports. If this hasn't been done already. These have quite a high compression already, don't they?
Posted: Fri Apr 01, 2016 6:16 pm
by Doom Patrol
I'd forgotten about that. Shows you shouldn't post things late at night. :oops:
eadmr04. It has a standard GP airbox. The original TV box is squashed on one side and restricts air. The filter itself is a washable fast flow filter I think came from Cambridge Lambretta. As for the gearbox I changed it some time ago for an SX200 box. Although, it pulls so well I believe it would pull the original.
But, other than that it is largely original..... :D
Posted: Fri Apr 01, 2016 6:43 pm
by Muppet
TV200 is a pedigree tweek one part and you have to change another
