Billet hub and sip problem
Posted: Tue Mar 22, 2016 4:13 pm
by TS1-200
Having a problem fitting a Sip rim to a pepperpot billet hub, don't know the make of the hub as was on the scoot when a mate bought it the caliper is fouling the rim, any thing tha can be done ? or will it just not fit, any ideas
Re: Billet hub and sip problem
Posted: Tue Mar 22, 2016 6:44 pm
by wack 63
It looks like a PM Tuning disc hub and I presume the rim nuts are hitting the caliper? With a new build I turn the hub around so the disc is on the offside but if you did this you would need to weld the anti dive bracket on the opposite leg, these are available from PM.
Posted: Tue Mar 22, 2016 7:06 pm
by TS1-200
Yes, and the valve, so what is the procedure turning round the hub, as I can't see how you can turn the hub around, and alter the position of the wheel fixing in relation to the calliper mounting
Posted: Tue Mar 22, 2016 7:59 pm
by wack 63
PM sent
Posted: Wed Mar 23, 2016 12:54 am
by rosscla
Difficult to see on a phone but isn't the wheel on the wrong side of the hub?
Posted: Thu Mar 24, 2016 11:37 am
by corrado
Edited ....
Ignore me .... senior moment.
