Page 1 of 2
Electrical guru's
Posted: Sun Mar 20, 2016 8:50 pm
by psychedelicropcircle
I've rebuilt an engine and pulled the bodywork off to replace loom & cables. At this point I have the engine in the frame and fired to do the timing. It's back firing all over the shop and sounding s**t. Would this be because I have no earths attached other than the CDI? Or should it run as normal without the earths attached?
If it's not the latter then I'll work my way back from the plug!
Re: Electrical guru's
Posted: Sun Mar 20, 2016 8:55 pm
by rosscla
It should run, provided -
1. The stator white is connected to the earth on the engine and good.
2. The CDI is earth properly to the frame.
Backfiring is usually due to bad timing.
Posted: Sun Mar 20, 2016 9:29 pm
by mick1
might be worth connecting a wire from the casing to the frame to be on the safe side
Posted: Wed Mar 23, 2016 4:10 pm
Turns out I'm shearing woodruff keys :oops: do they come in different sizes....just to f@@k you up like :twisted:
Posted: Wed Mar 23, 2016 5:54 pm
by coaster
The woodruff key is only there to ensure the flywheel is correctly aligned on the crank, it's the taper and nut that stop it spinning. You are either not tightening the flywheel nut sufficiently or the taper needs lapping in with some grinding paste.
Posted: Wed Mar 23, 2016 7:18 pm
by rosscla
Take the stator out and get some fine grinding paste. Place a little smear on the crank taper, fit the flywheel without the key and rotate the flywheel till you get a nice even grey finish on both mating surfaces of the taper. Clean it thoroughly refit the stator and key check the key is a good fit in the key way, then refit the flywheel.
Does your torque wrench work left handed ? Some do not.
Posted: Wed Mar 23, 2016 7:43 pm
by hendy
Is it possible to fit an li flywheel to gp crank or vice versa?
If it is, then could that be the cause of shearing?
Posted: Wed Mar 23, 2016 10:20 pm
by Monty
I normally shear mine when I'm setting the timing, I'm always tempted to just nip it up after moving the stator a bit then do it proper job at the end. I lapped it in and replaced the key and then all ok. I don't use the old earth to flywheel casing on any of mine. The engine is earthed through the CDI, make sure to have a good earth to the frame.
Posted: Wed Mar 23, 2016 10:36 pm
It's not an LI crank. It seemed like the the key slot was deeper on the meceur crank than the BGM. I'm off to Whitby at the weekend so I'll source some woodruff keys.
And yes I have a LHT Torque wrench
Posted: Thu Mar 24, 2016 10:09 am
by HxPaul
psychedelicropcircle wrote:It's not an LI crank. It seemed like the the key slot was deeper on the meceur crank than the BGM. I'm off to Whitby at the weekend so I'll source some woodruff keys.
Make sure it torques in the opposite direction (left handed)I thought mine did,until I realised it just ratcheted in that direction.
