T 5 clutch
Posted: Thu Mar 17, 2016 11:13 pm
by jonboy
My t 5 classic lurches forward when pulling away
Any ideas
Re: T 5 clutch
Posted: Fri Mar 18, 2016 1:20 am
by ipman
They don't have a reverse gear if that's what your asking
Re: T 5 clutch
Posted: Fri Mar 18, 2016 8:03 am
by Toot-oasc
jonboy wrote:My t 5 classic lurches forward when pulling away
Any ideas
Is it used regularly? If not it could be the clutch plates sticking together, then releasing suddenly causing the 'lurch'.
Or, the plates could be worn and need replaced?
Re: T 5 clutch
Posted: Fri Mar 18, 2016 5:58 pm
by ducksta
new plates fresh oil fresh inner cable sorted soak plates overnight in a plastic bag i find best
Re: T 5 clutch
Posted: Fri Mar 18, 2016 5:59 pm
by ducksta
and check the turrets have no burrs on them
Re: T 5 clutch
Posted: Fri Mar 18, 2016 11:46 pm
by shamrockexpress
A big part of this problem is the springs being done, change plates and springs together preferably piaggio genuine parts.
Otherwise buy complete new clutch unit plug and play.
good luck
