Gt186, bgm clubman, phbh30
hendy
Starting point for jetting please?
I currently have
Main 135
Slide d45
Needle x13 (2nd from top)
Atomiser av266
Idle 55
Fixed ignition at 18degrees
storkfoot
With a Ram Air filter:
Main 122
Atomiser/ needle AV264/ x13 2nd top
Slide 40
Pilot 55
Choke 70
Needle valve 300
shamrockexpress
28mm open mouth
main 135
atomiser av268
x7 clip 2nd from top
55 pilot
40 slide
70 choke
all good, here.
dont think you are too far away...................good luck
hendy
Thanks gents.
I'll go out and see if I'm any good at plug chops!
I wish there was a dyno near me :(
