Carbon fibre legshields
Posted: Thu Mar 17, 2016 4:11 pm
by gp200ts1
Anyone fitted pm carbon fibre legshields? Dry building the gp and the legshields rub on the main frame tube stopping me from dropping them low enough on the steering stem to have a gap between them and the handlebars. If I put double thickness anti vibration washers on the struts it helps but it still doesn't end up with a gap.
Re: Carbon fibre legshields
Posted: Fri Mar 18, 2016 9:34 pm
by thesx200
I removed the forktube clamp and refitted it in the correct position on mine, This was the only way to make them fit with neat gaps , infact the clamp fell off whilst pulling the legshields around during the dry build,
Posted: Fri Mar 18, 2016 10:01 pm
by TED CRUD
Looks like i will have fun fitting mine
Posted: Sat Mar 19, 2016 11:24 pm
by gp200ts1
thesx200 wrote:I removed the forktube clamp and refitted it in the correct position on mine, This was the only way to make them fit with neat gaps , infact the clamp fell off whilst pulling the legshields around during the dry build,
My clamp isn't fitted, I'll sort it when I'm happy with the positioning
