The ofishul bleeding your semi hydraulic inboard disk method
Posted: Mon Mar 14, 2016 10:20 am
by psychedelicropcircle
Ok my method is to remove the cap on the reserve (behind the horncast) then syringe the fluid up through the calliper until the air is pushed out. Then squeeze the lever and nip up the bleed bolt. The wheel is out the forks and laying flat whilst doing this.
Is there a different way?
Re: The ofishul bleeding your semi hydraulic inboard disk me
Posted: Tue Mar 15, 2016 7:49 pm
I take it I'm flying solo here? Thought t'others would have this nippy task ( every start to a season for me ).
Posted: Tue Mar 15, 2016 8:31 pm
by storkfoot
That seems a good way. I lay the wheel flat too and that certainly helps in minimising bubbles down there. My master cylinder is on the headset but I always take the lever off and depress the piston with a pencil. I presume if you are taking the horncasting off you could make sure the piston is fully depressed each time you pump too?
Good luck. Sometimes I get it to work very quickly. Other times, well we have all been there.....
Posted: Thu Mar 17, 2016 3:26 pm
Any ideas where I can purchase the two part bolt that holds the banjo?
Posted: Thu Mar 17, 2016 3:42 pm
Sorted
Posted: Thu Mar 17, 2016 11:29 pm
by Jazzy
Be very careful if you run BGM or fat dampers or the first time you brake hard it will snap it straight off.
Posted: Fri Mar 18, 2016 10:53 pm
Jazzy wrote:Be very careful if you run BGM or fat dampers or the first time you brake hard it will snap it straight off.
Are we talking from experience here? I'd imagine your brake lever hits the handle bar, whilst you hit Wots in fro t of you
Posted: Sun Mar 20, 2016 8:57 pm
by Jazzy
Yes from personal experience.
luckily it just snapped off the part you put the bleeding hose over.
