led bulbs
Posted: Sun Mar 13, 2016 8:23 pm
by philcasino1973
anyone know of a british supplier of led bulbs for pathfinder lamps ...need a pair soon and can only find chinese that could take a while to come
ta phil
Re: led bulbs
Posted: Sun Mar 13, 2016 9:37 pm
by coaster
The Chinese ones will be with you in about a week I would guess. I've ordered a fair few bits and pieces from China and have usually been amazed at the speed of delivery.
I'd be interested to hear how they perform, LED lamp technology has come on leaps and bounds.
Re: led bulbs
Posted: Sun Mar 13, 2016 10:01 pm
by philcasino1973
will order a pair and let you know how they are ...if they come before scooter is due to go to new owner
regards
phil
Re: led bulbs
Posted: Mon Mar 14, 2016 12:30 am
by afandy
If they are anything like the the supposedly 80w headlight bulbs ...Don't Bother ...I expected so much more ....they are very white .....but not as good as a 35w halogen ...a disgruntled scooterist
Re: led bulbs
Posted: Mon Mar 14, 2016 8:57 am
by Monty
Pathfinder uses a great pre focuses system so work great with a standard lamp giving a good beam. I have tried several LED type and have yet to find anything half as good. I'm using 6w Cree with a condenser type lens built in the front. It had several grooves cut round the aluminium lamp and I experimented how deep into the reflector the lamp sat. I made some small half moons to mount the lamp. It's not perfect but the light is very white so is akin to my HID headlight. The incandescent lamp was very yellow. For your mod types with lots of spots You van get Cree LEDS in most fittings that use minimal wattage
Re: led bulbs
Posted: Mon Mar 14, 2016 9:03 am
by coaster
afandy wrote:If they are anything like the the supposedly 80w headlight bulbs ...Don't Bother ...I expected so much more ....they are very white .....but not as good as a 35w halogen ...a disgruntled scooterist
If you tried it in a standard Lambretta headlamp Andy you were wasting your time as the reeded glass diffracts the light all over the place. The Jockey's headlamp uses a modern clear lens and a shaped reflector and should work much better with a modern LED lamp. That said, reviews I've read comparing halogen/LED/HID in the same light unit indicate that the HID is significantly better but the LED was better than the halogen and drew much less current....heat can be a problem with LED's though.
Re: led bulbs
Posted: Mon Mar 14, 2016 9:13 am
by mickymidas
Geezer in Old Bike Mart advertises led bulbs for all sorts of old bikes & scooters , might be worth a Google .
Think his name is Paul Goff , but ain't got a copy to hand at mo .
Re: led bulbs
Posted: Mon Mar 14, 2016 7:21 pm
by wack 63
Re: led bulbs
Posted: Tue Mar 15, 2016 10:31 pm
by afandy
Cheers Coaster for the explanation ...
