temperature readings
Posted: Sun Mar 13, 2016 4:18 pm
by smoore-gt225
hi been for a bit of a ride this morning and temperature gauge on the sip speedo with sensor on top of the plug
was normal riding with others say 40-50 mph was reading 170-175 degrees Fahrenheit
when I ragged it a bit on way home say upto 75mph it was hovering around 200 degrees Fahrenheit does this seem alright
plug chops etc all seem to be fine oh its ts1
cheer steve
Re: temperature readings
Posted: Sun Mar 13, 2016 9:54 pm
by roadrunnerian
you'll be ok up to at least 350 m8 if anything above start to use the choke
Posted: Sun Mar 13, 2016 11:40 pm
by shamrockexpress
Any body have an idea if there is much difference between sensor ring on top of the plug and solid fix to cylinder head fins?
Posted: Tue Mar 15, 2016 11:25 am
by dansacred
seems a bit warm, im cruising 140-150 and 175-180 giving death
ts1, under the plug. take your sensor and stick it in boiling water, see if the base reading is 100
Posted: Tue Mar 15, 2016 11:48 am
by coaster
The problem with bolting to a fin for me would be that it is too far removed from the combustion area to give an accurate account of what's happening and the response will be delayed. Plenty of people do do that though but usually report much lower temps. I did read somewhere of someone putting the probe on top of the plug and holding it in place with a piece of fuel hose so that it stayed in contact with the metal part of the plug. Haven't tried it myself though.
Posted: Tue Mar 15, 2016 4:01 pm
by alanscottj
I have my sensor over the plug and with the bit of fuel line in between it and the plug as suggested above. Seems to work, I'm only getting readings no more than 125 but I am only running in and haven't been over 50 (on Ts1).
