Head gasket horror
Posted: Thu Jun 25, 2009 10:06 pm
by ArmandTanzarian
Well that would explain why I was having so much trouble jetting up the new exhaust and why I spent an hour and a half freezing my nuts off by the side of the road waiting for the AA last night!
while we're in the barrel.... does this piston look like its coming up too far. With a thick head gasket the squish is around 1mm.
Re: Head gasket horror
Posted: Thu Jun 25, 2009 10:10 pm
by davidblythe
no problem running with negative deck clearance
reason why i dont use head gaskets unless they are 1.8mm thick
Posted: Thu Jun 25, 2009 10:14 pm
by ArmandTanzarian
What is the recommended squish for a tuned indian barrel? the bloke that did the work said that 1mm was fine.
Posted: Thu Jun 25, 2009 10:17 pm
by davidblythe
better to pack up with the base gasket to run without the head gasket
as in your case with negative deck clearance you have lowered your exhaust and tfr timings whilst increasing the inlet timing from standard
1 to 1.5mm is fine
normally find the squish increases across the piston as the cylinder head is not machined correctly
Posted: Fri Jun 26, 2009 8:11 am
by Special X
1mm is pushing your luck for road use. I'd use a nice thick original style hallite base gasket and set your squish to 1.4/1.5mm fit a good quality gasket to perfectl clean surfaces and preferably lap the mating surface on a mirror or similar flat surface prior to assembly.
Posted: Fri Jun 26, 2009 11:13 am
by ArmandTanzarian
I've put in an extra base gasket. It only makes about 0.3mm difference but better safe than sorry.
