lurching
Posted: Thu Mar 10, 2016 9:22 am
by willow
Hi guess im new to all this so be gentle. need a bit of help.problem is when I change down gears from 4th to 3 rd at any speed over 10 mph the back wheels seems as thou it wants to lock up and feel like you have hit the brake for a second.apart from this the scooter and gears are fine the rest of the time .any ideas please.
Re: lurching
Posted: Thu Mar 10, 2016 4:46 pm
by sean brady scooters
sounds as though you may just be changing down a gear without bringing the revs up to match the higher ratio ,try "double de clutching " :)
Re: lurching
Posted: Thu Mar 10, 2016 9:36 pm
by ducksta
What engine is it as I know lml engines do this from time to time
Re: lurching
Posted: Fri Mar 11, 2016 4:25 pm
by willow
Tried double dipping the clutch as for the engine its a t5 I would understand if I was doing it at a higher speed but not 10 miles an hour.under the 10 mph and it fine. Could it be crusiform or cush drive .I'm only guessing.
Re: lurching
Posted: Sat Mar 12, 2016 8:38 am
by mickymidas
Cruciform wear is usually indicated by jumping out of lower gears when changing up. May be you just have a good clutch in, try letting the clutch lever out slower when changing down so it's not snatching when the clutch is dis engaged ?.
Re: lurching
Posted: Sat Mar 12, 2016 1:03 pm
by Shaunbond
What's it like for a standing start in first? If it lurches and possibly makes a dry creech sound its the clutch. As Dusksta says LML clutches are known to do this, I've had 2 do the same, I swapped for two known good clutches and both were cured.
Re: lurching
Posted: Mon Mar 28, 2016 8:53 pm
by Spreader
Sounds like broken springs in the cush drive.
