Franspeed Supertourer
Posted: Mon Feb 29, 2016 10:54 pm
by prestonblast
does the above exhaust fit easily to a standard 125 LI without having to do any cutting or fettling? I am a crappy d.i.y'er :D
Re: Franspeed Supertourer
Posted: Mon Feb 29, 2016 11:18 pm
by Grumpy225
Series 2 or Series 3?
Expansion chamber type exhaust?
Typically, over the kick start expansion chambers will hit the right side floor board at the tail end.
Posted: Mon Feb 29, 2016 11:33 pm
by storkfoot
Yes, you will need to cut the rear of the runner board. It takes about a minute with a dremmel ;)
I have to ask - is the engine a standard 125 :?: :?:
Posted: Mon Feb 29, 2016 11:51 pm
by prestonblast
Series 3 with a 186 kit. Is the Franspeed over the top for my engine?
Posted: Tue Mar 01, 2016 8:08 am
by storkfoot
Depends on what "186 kit" you are talking about.
Posted: Tue Mar 01, 2016 7:29 pm
by prestonblast
It's a Mugello kit.
Posted: Tue Mar 01, 2016 8:49 pm
by storkfoot
I asked just in case you were thinking of one of the cheap Indian alloy barrels that are often seen on ebay. Anyway, in answer to your question, I can't speak from experience as my Supertourer is on a TS1. However, having had a Mugello at one time, I would say that it would probably work pretty well with appropriate gearing and a decent carb.
Posted: Tue Mar 01, 2016 9:13 pm
by ulyssescale
I've used a Franspeed ST pipe on a Jet 200 and no cutting of anything was required.
Posted: Wed Mar 02, 2016 4:22 pm
by bazza3004
Not sure how the st compares to the race at the back end . I cut an arc out of the back drop down section of the runner to aid clearence.
