Page 1 of 2
What am I doing wrong
Posted: Fri Feb 26, 2016 7:43 am
by nellyboyo
I`ve just just tried my hand at the whole panel beating and spraying thing on my s2. so I`m a beginner.
Learnt loads ( like satin black is a swine to spray ) , but the paint just doesn't seem to want to take to my oiltek cut down rear foot boards. I roughed them up a bit , etch primered them , then primered and sprayed and lacquered but the paint is coming off with the petrol a bit now.
They are steel but there's something about them the paint doesn't like ?
Re: What am I doing wrong
Posted: Fri Feb 26, 2016 8:26 am
by Chris in Margate
Paint hardened off and petrol resistant lacquer ?
Posted: Fri Feb 26, 2016 10:09 am
by nellyboyo
Yes to both, I bought resistant lacquer deliberately ..
Posted: Fri Feb 26, 2016 1:23 pm
by Monty
I have found very few true Petrol resistant Lacquers in spray cans. It gives a nice shine but just washes off. Some one may know of better ones I used the Halfords one and others in the past. spoke to a guy at Colourtone and he didnt have anything better even the ones marked 2 pack are not true 2 pack as they would set in the can.
Posted: Fri Feb 26, 2016 1:50 pm
by coaster
You need 2k lacquer, you can buy it on ebay. The can had an activator underneath that releases the hardener and means that the contents of the can will go solid within about 24 hours at room temperature. However, if you put it in the fridge it will remain usable for a least a week (turn it to the lowest setting). Worked for me
You will need a 2k compatible mask though, disposable ones are also available from ebay, usually twin filter jobbies but do make sure 2k is mentioned. Mine is a 3M one.
Posted: Fri Feb 26, 2016 2:34 pm
by nellyboyo
Cheers for that boys , I've found that now I've done a bit of spraying..... I want to go back and improve what I've already done .
Posted: Sat Feb 27, 2016 12:16 am
by GBCS
nellyboyo wrote:I`ve just just tried my hand at the whole panel beating and spraying thing on my s2. so I`m a beginner.
How much petrol are you getting on them ?
It shouldn't be coming off unless they are soaked, or have continual exposure ( like round the tank filler neck )
Posted: Sat Feb 27, 2016 12:42 am
by GBCS
Can you post some pictures ?
Posted: Sat Feb 27, 2016 7:37 am
by nellyboyo
No, I can`t post pics, I`m away at work . They are soaked in petrol spit back as it`s running a bit rich .
I`ll take them back to bare metal again and try again with 2k lacquer then I think
Posted: Sat Feb 27, 2016 5:50 pm
by GBCS
How did you clean the panels before the etch primer ?
