li 150 or gp 200 ?
db67
hi, currently running an li 150 gearbox with 17x48 sprockets (4:80) on my ts 225 with a jl 3 pipe & i just wondered if there would be any advantage gained by fitting an indian gp 200 gearbox with 19x46 sprockets (4:84) ? thanks for any info. db :)
The final drive ratio difference is marginal....if thats what you are thinking about? Both are close ratio, but the GP gives clutches an easy life with the use of 18 & 19 tooth front sprockets
If its just the final drive ratios you are thinking about.....i'd save yourself the chew, and just stick with the Li box...maybe try 16/47 (4.99) i run that on my racer....and it goes well.
Funkspeed
Main scooter: Rally 200
I'll be keeping the GP200 'box on mine when I drop the TS1 in shortly....currently running a Rapido 225 and the 'box seems to suit that really well so hopefully will be just as good for the TS1.
