Routing the rear brake cable
Livi- Graeme
Main scooter: Lambretta li 185 series 2
Mates restoring an sx150 fitted with an imola. The brake cable doesn't seem to want to go the normal route. Do you route it over the carb reed valve?
Boreham
Main scooter: GP225
Livi- Graeme wrote:Mates restoring an sx150 fitted with an imola. The brake cable doesn't seem to want to go the normal route. Do you route it over the carb reed valve?
Correct goes over the top, however due to this it comes up slightly short, i just used one of the extended top hat cable ferrule at the brake end, sorted, about £5 of flee bay
Livi- Graeme
Thought so just looks so wrong. Cable is long enough to fit into both ferrules. Thanks for the reply. Graeme
sydduckett
I have a Ron moss oversized head plus reed block, talk about go round the houses.... :D
Livi- Graeme
Who needs a back brake anyway!!!!
DigDug
sydduckett wrote:I have a Ron moss oversized head plus reed block, talk about go round the houses.... :D
+1 - A right pain to get it sorted. ;)
Did you have to do that?
I also have an Avanti head on my TS1 and this thread had me wondering, just checked and I routed mine under the carb. If I had gone over it would have got in the way of the plug cap :?
sydduckett
Mines on a rb so carbs in the way, just missed the plug. I run my gear cables through the frame as theres just to much going on under the legsheilds. Works welll.
Bufficus
My two penneth.
RB Avanti head TMX 35 on an LTH manifold. I have to route mine around the carb. Extra top hat at both ends of cable. Looks shite and feels wrong but works. Can't see it with the panels on.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 18 guests
