Page 1 of 2
pacemaker gearbox
Posted: Fri Feb 19, 2016 3:08 pm
by garry inglis
just bought my new project a nice 1964 li150 silver special as original as you can get can some one tell me when they changed the week gearbox 3rd on these all I can find is early ones had a week 3rd thanks
Re: pacemaker gearbox
Posted: Fri Feb 19, 2016 3:10 pm
by bsso78
Are you leaving it standard
Posted: Fri Feb 19, 2016 3:58 pm
by garry inglis
i am giving it a full nut and bolt resto as a true special but i have a nice af 175 iron kit from my other scoot and a25mm delorto af 42 box ithink that will be the only changes just to give it a bit more wumff i am going to take a lot of pics and i wil post some up
Posted: Fri Feb 19, 2016 6:02 pm
by bristolmod
if its that original why bother doing a resto? As Coxy used to say- "they are only original once!"
Posted: Fri Feb 19, 2016 6:23 pm
by ducksta
agree with chris leave it alone or treat it to a descent engine and upgrades brakes suspension etc
Posted: Fri Feb 19, 2016 8:39 pm
by wack 63
My '65 import had the thick 3rd gear but the earlier drilled cluster and as far as I could tell no one had been inside the motor,so it was either fitted in the factory or went to a service centre.
Posted: Fri Feb 19, 2016 8:42 pm
by garry inglis
thanks wack63 when you say thicker by what 2 or3 mm I bet there is something in stickys bible
Posted: Sat Feb 20, 2016 9:37 am
by wack 63
The teeth on the loose 3rd gear are visibly thicker on the end compared to the other gears.
Posted: Sat Feb 20, 2016 9:56 am
by bsso78
ill come round and have a look at it
Posted: Sat Feb 20, 2016 4:16 pm
by shamrockexpress
