Reading the readings.
Posted: Wed Jun 24, 2009 11:00 pm
Tried an old SIL leccy kit I had and got one spark then nothing, dead as a door post, tested it and got 645 on the green and 101 on the red, got fed up checking the wires etc so brought a 120 BGM stator from JB, checked that quick and got 536 on the green and 113, put it on and its like a new scoot, so whats that all about then?
SO...is 645 good or bad? does it show that there is a failure somewhere? I'm baffled by the readings.
The only thing I changed was the stator, same CDi and flywheel and its now running great, pulls better thru all the gears than the points I had before (which started playing up).
