italian gp 200 gearbox
Posted: Sat Feb 06, 2016 5:24 pm
by a.lo.v2
going through the old bits and found an italian GP 125/200 cluster and 3 third gears ?, would like to make up the set, there seems to be a few options looking at stickies gear chart(third gear dimensions wrong in first edition) indian 200 2 and 4 look the same are they a straight swap? and sx150 and vj150 1 and 2 seem to match, are these options possible? any thing to look out for when i go for a rummage at the next parts fair.
Re: italian gp 200 gearbox
Posted: Mon Feb 08, 2016 11:15 pm
by a.lo.v2
anyone? are those gear options correct? please.
Posted: Mon Feb 08, 2016 11:31 pm
by Padge
I have an Italian gp box with 2 teeth missing on 4th gear and 1 missing off the Christmas tree, if I understand your post you have a Christmas tree so with what I have here all you would need is a 4th gear....am I correct ?
Posted: Tue Feb 09, 2016 4:45 pm
by a.lo.v2
basically i need 1st,2nd and 4th loose gears, and it looks like these are not unique to the gp200 box so looking at options.
Posted: Tue Feb 09, 2016 5:53 pm
by garry inglis
the li special and gp125 are the same as gp 200 they just use different sprockets
Posted: Tue Feb 09, 2016 8:25 pm
by Padge
like I say, I have gears 1, 2 and 3 if they're any use to you
Posted: Wed Feb 10, 2016 12:37 pm
by Special X
Indian 1,2, and 4th gear are the same. 3rd gear, and Christmas tree are different.
Posted: Wed Feb 10, 2016 5:24 pm
by TS1-200
Yes you should be able to use Indian 1st 2nd & 4th gears with your cluster and 3rd gear. you already have the hardest parts to find
