190cc card setup info
Posted: Sat Feb 06, 2016 3:22 pm
Hi all a little jetting advise needed please..
just finished rebuilding my s3li engine new gp200 crank (58-110) upgrade
my set up now is
175 steel barrel bored to 190cc (by MB) Yamaha piston
sterling big bore exhaust
timing at 19deg
original 150 gear box
28mm delly PHBH BD
Which bring me to main question brought this second hand and this is whats inside
main 122
pilot 57
atomizer BN266
slide 45
needle x25
choke 70
needle valve is 250 not sure of float weight
after trolling through carb set ups on here im guessing most need changing
Thanks for reply's/info
Lee
my set up now is
timing at 19deg
28mm delly PHBH BD
main 122
pilot 57
atomizer BN266
slide 45
needle x25
choke 70
Lee
