Broken cylinder skirt
vicvega
Main scooter: Scomadi
You hear a lot about ali barrells getting relined but is there anything you can do with a cast iron barreel with a broken skirt. I've got a GT barrell that has cracked both vertically and horizontally on the skirt, is there anything I can do about this to get it repaired?
alanscottj
I have a Mugello 198 that I dropped, lost a huge chunk of the skirt but I've never had a problem with it :D
Rich_T
Main scooter: Li Special
post a picture, lets see.
vicvega
Hope these are clear enough to see, there is a crack in a capital T shape, hope I posted pics properly.
Don't see why you couldn't just machine it round just above the crack
bristolmod
I've done that before right up to the "step"- no problems in running at all.
Scootering since 1968.
vicvega
Cheers fellas that's good to know. Thought I was gonna have to scrap it.
Rich_T
That's and interesting break how did it happen? It should be OK to grind the crack into a slot with a radius at the end to stop the crack propagating. I've seen iron barrels run with big chunks of skirt missing so as long as you've resolved the original issue and there is no likelihood of a piece breaking off then you should be OK.
jimmers
Has anyone tried and been successful with the cast iron stitch welding they do? Is it cost effective or better to just replace?
Rich_T
I would not recommend it at all. You build up a lot of heat stress particularly in thing sections, if it were a car engine block maybe.
