italian gp 200 gearbox
a.lo.v2
Main scooter: sx 200
going through the old bits and found an italian GP 125/200 cluster and 3 third gears ?, would like to make up the set, there seems to be a few options looking at stickies gear chart(third gear dimensions wrong in first edition) indian 200 2 and 4 look the same are they a straight swap? and sx150 and vj150 1 and 2 seem to match, are these options possible? any thing to look out for when i go for a rummage at the next parts fair.
a.lo.v2
anyone? are those gear options correct? please.
Padge
Main scooter: 1969 Lambretta gp
I have an Italian gp box with 2 teeth missing on 4th gear and 1 missing off the Christmas tree, if I understand your post you have a Christmas tree so with what I have here all you would need is a 4th gear....am I correct ?
a.lo.v2
basically i need 1st,2nd and 4th loose gears, and it looks like these are not unique to the gp200 box so looking at options.
garry inglis
the li special and gp125 are the same as gp 200 they just use different sprockets
Padge
like I say, I have gears 1, 2 and 3 if they're any use to you
Special X
Indian 1,2, and 4th gear are the same. 3rd gear, and Christmas tree are different.
TS1-200
Yes you should be able to use Indian 1st 2nd & 4th gears with your cluster and 3rd gear. you already have the hardest parts to find
Keep on keepin on
    Users browsing this forum: Google [Bot] and 16 guests
