Page 1 of 2
Clutch problem?
Posted: Sun Jan 31, 2016 10:33 am
by dave411
Just got my engine running,but when I put in firstor second,the engine stalls.Its an AF road cassette clutch,and the lever on the top of the gearbox is moving ok.I have put sae 90 in the gearbox.I am thinking that maybe the plates have stuck together?
Thanks.
Re: Clutch problem?
Posted: Sun Jan 31, 2016 3:59 pm
by Jonn
With the engine off pull in the clutch and kick it over, the kick start should smoothly go down.If it doesn't you need to tighten the cable.
Re: Clutch problem?
Posted: Sun Jan 31, 2016 4:17 pm
by rosscla
Or the plates are sticking in the basket.
Did you check they all fitted smoothly before assembly? I have heard some say the road version sometimes needs a bit of fettling for smooth operation.
Re: Clutch problem?
Posted: Mon Feb 01, 2016 12:35 am
by bazza3004
As above . The cassette should drop in and out of the basket freely. I find motul 2t 10/30 transoil much better than the st90.
Re: Clutch problem?
Posted: Mon Feb 01, 2016 9:16 am
by dave411
Thanks for the replys guys.I have stripped the clutch and found the steels to be quite rough and a bit rusty.Have cleaned them up and reassembled.Will re assemble tonight and let you know how it goes.
Re: Clutch problem?
Posted: Mon Feb 01, 2016 9:18 am
by rosscla
Connecting the dots - are you using the AF clutch with an Li style side casing and cam?
Re: Clutch problem?
Posted: Mon Feb 01, 2016 9:46 am
by dave411
Yes.
Re: Clutch problem?
Posted: Mon Feb 01, 2016 10:43 am
by HxPaul
If its been left for any length of time sometimes the plates wont seperate when put in gear with the engine running and the bike stalls.Its happened to my scooter on a few occations,in this case what I've done is rev the scooter as I put it into gear and this is usually enough to seperate the plates.
Re: Clutch problem?
Posted: Mon Feb 01, 2016 11:34 am
by dave411
I think that was the case,will find out this evening.
Re: Clutch problem?
Posted: Mon Feb 01, 2016 6:42 pm
by rosscla
Does it have an optional nipple type centre for use with an Li casing?
I thought these were designed with the flat type centre for GP casing.
