What size carb?
Posted: Wed Jan 27, 2016 9:37 pm
by Trekker si
Hi I'm running tv200 with taff/speed exhaust just wondering what's the best size carb to run ?
Re: What size carb?
Posted: Thu Jan 28, 2016 12:33 pm
by rosscla
What state of tune is the cylinder?
How does it run now?
What are you hoping to gain / achieve?
If it's standard then you could probably just upjet the standard one.
Using the SH2/22 (Scootopia or fettled Jetex) such as the GP used might give a slight boost as it's a slightly more modern (late 60s compared to early 60s for the SH1) design.
If you're not to bothered about originality then some like a PHBL25 would also give a useful boost and can still be run through the airbox.
Just bear in mind that any bigger carb can come with a sharp decrease in fuel economy for very little gain in usable power. Back in the 80s the first thing you did was slap on an 30+mm Amal and a fresco and claim it went fast as fook. The likelihood was that it made more noise, spat all the petrol up your leg and really didn't go much better.
Re: What size carb?
Posted: Thu Jan 28, 2016 7:13 pm
by Trekker si
It's running on a standard carb now, but can't get it to tick over, idle scene is not hitting the plate to adjust
Re: What size carb?
Posted: Thu Jan 28, 2016 8:09 pm
by Chris in Margate
Buy another secondhand SH1/20. Strip, clean and use all best parts. In standard tune, not really much to be gained other than slightly more induction roar and slightly worse fuel economy.
Re: What size carb?
Posted: Thu Jan 28, 2016 9:55 pm
by Muppet
bend the plate/throttle stop so it touches sooner pliers are your friend
