Page 1 of 2
Broken cylinder skirt
Posted: Tue Jan 26, 2016 11:44 pm
by vicvega
You hear a lot about ali barrells getting relined but is there anything you can do with a cast iron barreel with a broken skirt. I've got a GT barrell that has cracked both vertically and horizontally on the skirt, is there anything I can do about this to get it repaired?
Cheers
Re: Broken cylinder skirt
Posted: Thu Jan 28, 2016 12:04 pm
by alanscottj
I have a Mugello 198 that I dropped, lost a huge chunk of the skirt but I've never had a problem with it :D
Posted: Thu Jan 28, 2016 7:41 pm
by Rich_T
post a picture, lets see.
Posted: Sat Feb 06, 2016 4:46 pm
by vicvega
Hope these are clear enough to see, there is a crack in a capital T shape, hope I posted pics properly.
Posted: Sat Feb 06, 2016 7:21 pm
by rosscla
Don't see why you couldn't just machine it round just above the crack
Posted: Sat Feb 06, 2016 9:54 pm
by bristolmod
I've done that before right up to the "step"- no problems in running at all.
Chris
Posted: Sat Feb 06, 2016 10:49 pm
by vicvega
Cheers fellas that's good to know. Thought I was gonna have to scrap it.
Posted: Sun Feb 07, 2016 12:12 am
by Rich_T
That's and interesting break how did it happen? It should be OK to grind the crack into a slot with a radius at the end to stop the crack propagating. I've seen iron barrels run with big chunks of skirt missing so as long as you've resolved the original issue and there is no likelihood of a piece breaking off then you should be OK.
Posted: Sun Feb 07, 2016 9:05 am
by jimmers
Has anyone tried and been successful with the cast iron stitch welding they do? Is it cost effective or better to just replace?
Posted: Sun Feb 07, 2016 10:39 am
by Rich_T
I would not recommend it at all. You build up a lot of heat stress particularly in thing sections, if it were a car engine block maybe.
