Wiseco Small end bearing
Posted: Tue Jan 26, 2016 9:21 pm
by Fruitjuice
Building a Monza kit with a 71mm Wiseco piston 423M07100.
The piston didn't have the small end bearing when I got it.
What small end bearing do I need? The gudgeon pin is 16mm but the space between the lugs is wider then a standard Lambretta piston.
Also, where can I find a Lambretta 225 5mm base packer?
Re: Wiseco Small end bearing
Posted: Tue Jan 26, 2016 9:53 pm
by shocky
Darrell taylor at taylor tuning google contact info
or Richard taylor on here
Posted: Tue Jan 26, 2016 9:54 pm
by HxPaul
Fruitjuice wrote:Building a Monza kit with a 71mm Wiseco piston 423M07100.
INA do a standard Lambretta 16x20x20 small end bearing,you can get a 16x20x22 Japanese small end bearing.
Posted: Tue Jan 26, 2016 10:16 pm
by jonashford
You don't normally get a small end with a piston
