5 speed gear selector position
Posted: Sun Jan 24, 2016 10:25 pm
by sydduckett
Whats the best place to position the gear selector arm on top of the chaincase for a five speed when setting up and which gear should be selected.
Ta
Sef
Re: 5 speed gear selector position
Posted: Mon Jan 25, 2016 12:04 pm
by Muppet
neutral
Posted: Wed Jan 27, 2016 9:33 pm
by Grumpy225
I always set them up starting in 5th (or 4th depending on the gearbox). This way you know the shift arm won't hit the shock mount. Just get it as close as you can without touching the mount and it will be fine.
Posted: Thu Jan 28, 2016 11:09 am
by a.lo.v2
i agree with Grumpy about "top" gear as i had a lot of trouble with false neutrals in the past,( not on a five speed). you can also hear a distinctive clunk in top so you know you are there. i say top gear, as there should be no difference with 4 or 5 gears as there is the same range of movement for both and you will know the lever clears the casing. i ride with a cyclone that i fitted a couple of years ago.
