PX200 bogging off idle
Posted: Sun Jan 24, 2016 1:22 pm
Hi all,apologies if this has been asked a thousand times,
Got a cutdown with a P2 disc engine,just recently opened it up and it was all in good condition but fitted new quality bearings and seals,honed the barrel and gapped a new set of rings.Ive built a few p range engines so I know my way around them,although I'm no expert!
Running a Simonini,
Timing at the A mark on stator
Carb all thoroughly cleaned out and standard P2 jetting with a 122 main,carb and box lapped on wet n dry paper (carb box matched to carb)
B7 plug,new lead and NGK cap,Ducati coil
New gaskets thoughout
Good fuel flow from fast flow tap
She starts and runs fine,no excess smoke,but sometimes it will bog down slightly when you blip the throttle.Tried adjusting the mixture screw either way from 1.5 turns out but still has this horrible boggy blip.Revs out fine apart from that and comes down do a steady idle straight after.
Any ideas,knackered carb maybe?
Running a Simonini,
