lambretta 290 rotax
czeckson
Main scooter: Lambretta SX150
Mon Feb 18, 2019 3:45 pm
holty
ebay user ID: amholt123
Main scooter: lambretta gp
Mon Feb 18, 2019 5:55 pm
garry inglis wrote:
Tue Feb 05, 2019 6:52 pm
whats the rubber cap with the spring clip steve is that for coolant
its the rave valve garry, works off exhaust pressure which lifts the valve up and down to alter the exhaust port timing, gives more torque at low revs and more power at high revs, a bit like a turbo on a car, first test ride was Saturday and its very very quick, did a power wheelie in second gear without even trying, its got way more power than it had before, and that was 35bhp, I still have the bigger carb to fit as well, that will got on when I get martin at chiselspeed to dyno it for me, I just want to get some miles on it first.
Image51960891_2311882732387243_4544355083143348224_n by stephen holt, on Flickr
holty
Mon Feb 18, 2019 5:57 pm
Wayne Miller
Thu Apr 04, 2019 3:24 pm
Cool project, have you thought about using an ignitech device for powervalve control instead of the diaphragm? I used one on my 50 special. they're pretty cool bits of kit. They control your PV Blade from the ignition so you can map it by RPM/Degree's
I'll grab a coffee and a packet of crisps and read this from start to finish tonight :)
Stay tuned..............
holty
Thu Apr 04, 2019 9:42 pm
im just running it in at the moment, by the time I get back from knarseborough it will be, I quite liked the idea of the valve been self governing, but I see how a programmable ecu would be of benefit, im looking forward to getting the big carb on and getting it on martins rolling road and see what power it has, it realy is a torque monster and such fun to ride.
holty
Thu Apr 25, 2019 9:44 pm
went to scarborough scooter rally, ran very well, ive done 500 miles now since rebuild, big carb going on next, then dyno time
ImageUntitled by stephen holt, on Flickr
holty
Sun May 12, 2019 9:11 am
got my 38mm carb fitted and took my scooter to martin at chiselspeed to get it set up correctly, got it on the rolling road and it managed 40bhp very pleased, took it for a ride yesterday and it is awesome, the blue line is my trace from last year and the red one is the results on Friday
RManson
ebay user ID: Ryanskidmarx
Sat May 25, 2019 7:36 am
Nice results Holty! Glad to see you're still getting after it!
holty
Sun Jun 02, 2019 9:01 am
cheers ryan, its running very well, just getting more miles on it, hows yours going ?
holty
Sun Oct 06, 2019 10:29 am
just a little update, this has been on the road now for 2 years which sort of surprised me, biggest fault ive had in that time has been the exhaust cracking, ive had a few electrical issues which ive addressed now, but it developed a few oil leaks, rear hub bearing and kickstart shaft which made me think I had a problem so I did a leakdown test and sure enough main seals have failed, so ive done a quick rebuild, new bearings and seals and rings as well, did a bit of work on the packer plate to match the ports better and ive done a bit of work on the inlet, I have also added a flexi joint the the exhaust to try and fix the splitting issue. I have also altered 2 of the exhaust mounts as well, time will tell if it cures the cracking, road test was fine seems very responsive.
