dr 180
Hammerite
Main scooter: Sx150
I've a dr 180 kit to put on a px . It doesn't have a head gasket .Is this right ?
Rich
gaz_powell
No head gasket on last one I did.
Before you fit lap the cylinder and head. I would also hone it to get a better (larger) bore to piston clearance (very tight out of the box) . Finally gap the rings.
grimspeed
Main scooter: gp 283 kx
And don't forget to chamfer all the ports !
fraserp200e
Main scooter: 1988 MotoVespa TX200
gaz_powell wrote:No head gasket on last one I did.
I'm in the process of building one as well. What should the ring gap be ideally?
1983 Vespa PX125
1984 MotoVespa P200E
