Dip pulling off in first
Posted: Sun Dec 20, 2015 7:56 pm
by Lamaddict
I noticed it on a few engines and it drives me mad. It's pulling away in first and the revs drop a bit. I once tried adjusting a slide but that didn't work. Once into 2nd etc it's fine. Set up at the minute is a GT186 (best smallframe Kit, IMO) 25 Dellorto and Clubman. Gearbox li125 16x46.
Re: Dip pulling off in first
Posted: Sun Dec 20, 2015 8:17 pm
by Chris in Margate
Carburation is probably too rich at full revs. Not noticeable in higher gears because engine load doesn't allow it to rev so high.
Posted: Mon Dec 21, 2015 12:27 am
by thackers
Check your spark plug gap.
Posted: Mon Dec 21, 2015 4:57 pm
by shocky
Is it just as you twist the throttle , like its gonna stall or run out of petrol ?
Posted: Mon Dec 21, 2015 5:07 pm
by Lamaddict
Yes it's worse when cold and it feels carb related. As I say, I noticed on a few scooters.
Posted: Mon Dec 21, 2015 6:27 pm
by mick1
are you using a lightened flywheel ?
Posted: Mon Dec 21, 2015 7:50 pm
by Lamaddict
^ yes
but it seems a carb adjustment would be possible but where and how? I did reduce the angle of a slide once but it didn't make any difference.
Posted: Mon Dec 21, 2015 8:54 pm
by shocky
Those symptoms can be the airscrew causing it be lean or the pilot jet is to small
Posted: Tue Dec 22, 2015 10:21 am
by eden
I agree with shocky on this one. To test it try pulling away with choke on.
Posted: Tue Dec 22, 2015 2:48 pm
by Lamaddict
Thanks all, I have a 50 pilot jet I'll try a 55.
