ArmandTanzarian wrote:How much would something like this cost in parts and labour?
Parts tally was a bit scary as this was a scratch build with all new high spec parts & no donor parts used... total cost of all parts was approx £3,400.00 (inc exhaust) - so with Sean's labour bill, the build cost totalled just over £4k... that's complete with pipe, rear hub, ect - basically ready to bolt-in & go...
The £3,400.00 covers the below list of parts used;
• Pinasco ‘Slave’ Small Block PX Cases
• Quattrini M1X 172 Kit
• Scooter & Service 60mm Reed Crank
• Scooter & Service 35mm Reed Inlet Manifold with Tassinari V Force 4 Reeds & Keihin PWK 35 A/S Carb
• New Bearings/Seals/Gaskets
• DRT Spitfire Cluster
• DRT 65t Primary
• Full DRT Loose Gears (55t 1st / 41t 2nd / 37t 3rd / 36t 4th)
• Piaggio PX Lusso Main & Input Shaft
• DRT 23t Clutch Gear
• BGM Super Strong Clutch + ancillaries
• Piaggio PX Lusso Selector Box, Selector Pin, Cruciform- ect
• Scooter & Service Clutch Cover
• Pinasco Flytech Ignition with 1600g flywheel
• MMW Billet Fan Wheel
• New Piaggio Rear Hub, Rear Brake Cam, Brake Arm, Shoes, Back Plate, Springs, Clips - ect
• Rally Kick Start Gear/Spring/Lever
• New Cowls & Covers
• Stainless Brackets & Fasteners, Shims, Misc items
• Pipe Design Bullet 177 Exhaust in Stainless
