Page 1 of 2
bad starting rb
Posted: Fri Dec 18, 2015 10:59 am
by rbgaz
hi all my rb 230 is a pig to start nowdays i have to cover the open mouth tm35 carb and kick it 20 plus times once it fires up it runs fine and starts easy when hot compression is ok any ideas
Re: bad starting rb
Posted: Fri Dec 18, 2015 1:25 pm
by holty
that could be worn rings
Re: bad starting rb
Posted: Fri Dec 18, 2015 3:19 pm
by coaster
Have you tried choking it with your hand over the carb? My guess would be that the choke isn't opening enough or at all. I had this exact problem with my TS1 earlier a while back, it was so hard to start I busted the kickstart
Eventually found that the nipple had come out of the back of the choke lever and the choke wasn't operating at all
Re: bad starting rb
Posted: Fri Dec 18, 2015 6:59 pm
by Adam_Winstone
Could be reed petals
Re: bad starting rb
Posted: Fri Dec 18, 2015 11:09 pm
by 22/2
I've just rebuilt the top end of my 250 as the starting was becoming more difficult, not to the level you describe the bottom ring was stuck in, back to normal now.
There is obviously something wrong you need to get it apart and have a look, it'll be cheaper than if something is wrong and it breaks, do it now before spring comes.
Re: bad starting rb
Posted: Sat Dec 19, 2015 1:51 am
by Mr G in NYC
Adam_Winstone wrote:Could be reed petals
+ One . G
Re: bad starting rb
Posted: Sat Dec 19, 2015 8:52 am
by rbgaz
The reeds are newish. I've had several sets of reeds fail in the past but not like this and yes I have to cover the mouth of carb with a cloth this is only way it will ever start
Re: bad starting rb
Posted: Sat Dec 19, 2015 12:40 pm
by dennis
Be very careful covering carb with cloth,i did that with some blue paper towel it sucked it straight through and out the exhaust,made us laugh afterwords tho.
Re: bad starting rb
Posted: Sat Dec 19, 2015 12:56 pm
by coaster
dennis wrote:Be very careful covering carb with cloth,i did that with some blue paper towel it sucked it straight through and out the exhaust,made us laugh afterwords tho.
My younger brother did that with his Garreli Rekord back in the early 70's. Sucked a lump of rag right in which compacted in the cylinder head
He had to take the head off to get it out, how I laughed
Re: bad starting rb
Posted: Sat Dec 19, 2015 2:46 pm
by rbgaz
I only use the missus finest tea towels ! Lol
