more air through filter
Posted: Wed Dec 16, 2015 10:58 pm
by scootcoot
Does anyone know how to turn a standard lammy airbox airfilter to let more air flow through ? (other mods have been done to the box inner cut out,holes in the box etc)
Re: more air through filter
Posted: Wed Dec 16, 2015 11:08 pm
by Grumpy225
There are a few tricks to getting more air in.
Remove air scoop restrictor
remove air box bellow/bladder
drill holes or punch louvers in air box
run a high flow mesh filter
all of them work okay. Have to keep in mind that the stock air box was not meant to flow a lot of air.
I put a standard air filer/box set up on a flow bench to see what we could do to improve the flow. We found out that a lot of the flow restriction came from the elbow that connects to the rubber boot. In the end I just removed the whole box and ran a remote filter.
Posted: Wed Dec 16, 2015 11:14 pm
by Doom Patrol
Try the BGM air filter. It's a wire mesh basically, and as far as I can tell very little restriction.
Posted: Wed Dec 16, 2015 11:59 pm
by scootcoot
Many thanks for the advice ...
Posted: Thu Dec 17, 2015 9:52 am
by dennis
I've got the BGM filter which i cover with oil to help catch particles,i let it stand for a couple of hours after oiling.
Posted: Thu Dec 17, 2015 11:28 am
by HxPaul
If your not using a cheap Indian Steel Bird filter element,but an Italian one,try changing to the Indian one because they let more air in due to the fact that they have a covering of wire mesh,Italian filters have a covering of steel drilled with holes and they are a lot more restrictive.
Posted: Thu Dec 17, 2015 1:38 pm
by barnsleybilly
If you really need a drastic increase in air then I'm with Grumpy225.
Better fitting a small foam filter directly onto the carb than trying to overcome all the other bottlenecks.
