acceptable conrod float in a MEC crank
scooterslag
What's the maximum conrod float in a black webbed MEC crank? Just got one for cheap and it's got 0.9mm of wear, is it still usable? It's going in a standard GP150, cheers Paul
The mack daddy on the left!
Is it shimmed?
If not, and using piston shims, then the standard crank maximum would be 1.50mm
scooterslag
It's not shimmed, good to find out it's still usable, cheers for the info, Paul
