Belt drive fitting
Posted: Mon Nov 16, 2015 7:29 pm
by Pompeydave
I've also got a belt drive kit that I bought from a well known auction site in 2013. No instructions came with it, but it is new and complete. There's an issue with the oil throw washer though- do I retain it? It would appear that the belt will rub on it if I leave the washer on. There is also a steel collar which seems to fit at one end or the other of the crank sprocket- it could go on the inside to hold the sprocket further off the crank case (but then the belt looks slightly kinked) or it goes on the outside which leaves the belt fouling the throw washer. Any ideas anyone?
Re: Belt drive fitting
Posted: Mon Nov 16, 2015 11:26 pm
by Pompeydave
Ok, I've fitted this tonight- ignore the front sprocket spring, I realised it's not needed with this setup.
This doesn't look quite right to me- the belt isn't sitting naturally on all three rollers.
Again, this looks mighty close to the endplate.
I managed to work out that the front sprocket should be set up like this. Not sure about what torque to set the bolt at though? Also, I don't know how tight the belt should be? I assume pretty tight otherwise it'll slip over the teeth.
Dunno, any idea's anyone? Might be fine as it is?
Posted: Tue Nov 17, 2015 12:52 am
by coaster
Camlam used to sell them, maybe worth giving them a call.
Colin
Posted: Tue Nov 17, 2015 8:30 am
by ArmandTanzarian
What is the advantage of a belt system?
Posted: Tue Nov 17, 2015 10:18 am
by Pompeydave
It's supposed to give a smoother running, quieter engine with less friction than a chain. Reckoned to be good for 40,000 km's too.
