BGM Ignition
Posted: Sat Nov 14, 2015 7:59 pm
Hello
This is my 2nd post here at Scootererotica. I've spent some time reading and searching the forum for some insight to an issue I am trying to solve but not sure I've found it so far here goes.
Having trouble with a BGM electronic ignition installed on a GL 150. Initially the ignition was working for a short time. The ignition was running for several minutes on the stand and about 5 miles testing on the road before the spark went away.
I checked the BGM CDI on a P200 which produced good spark.
I checked the BGM stator ohm readings the red and white wire measure 112 ohms and the white and green wire measure 500 ohms. The BGM readings were comparable to the readings I measured on a P200 stator.
I checked AC volts output with the BGM system installed and measured voltage on the white and red wire and the white and green wire but not producing a spark from the CDI.
I installed the P200 stator into the GL and was able to run the scooter with the BGM flywheel and BGM CDI. Tested AC output with P200 stator and again had similar readings that was observed with BGM stator only this seemed to work as good as I could expect.
Got another BGM stator and have the same symptoms, no spark. Everything seems to check out on the volt meter but no spark.
Any idea on what could be going on?
