Indian crank with RB rod.
Posted: Sat Nov 14, 2015 6:46 pm
by monkey boy
Anyone got any idea how much power you can put through these please?
Re: Indian crank with RB rod.
Posted: Sat Nov 14, 2015 7:35 pm
by Knowledge
I would have thought that 20bhp would be the top-end of the power.
How much power are you hoping for it to handle MB?
Posted: Sat Nov 14, 2015 8:13 pm
by dave wheeler
are these with a 116mm rod?
if so whose selling and how much?
Posted: Sat Nov 14, 2015 8:16 pm
by kevspeed
I got mine a while back direct from A.F,Indian webs and an RB rod/bearing,107mm rod,58mm throw,for my std TS1 set up,although ive not got round to fitting it all together yet!,I think it was about £130
Posted: Sun Nov 15, 2015 10:08 am
by monkey boy
Was hoping for 26 to 30 brake.
I have an Alpha crank I can use,might be better off using that.
Posted: Sun Nov 15, 2015 10:12 am
by monkey boy
Dave,you can get them made up at AF by sending them some Indian crank webs
107 or 116 RB rod kits fitted with the big end with the extra roller and you also get a quality small end supplied
Cost £145
Posted: Sun Nov 15, 2015 7:00 pm
by dave wheeler
cheers min
Posted: Sun Nov 15, 2015 7:56 pm
by IanGP
Nothing wrong with Indian webs or the AF RB rod. I would have said 20hp was a little on the safe side, should be ok in a tuned TS1 or RB if the cranks built properly with a good quality bearing, Webs are super strong and a nice tight fit on the crank pin, before all these posh cranks came out, people used to race on Indian webs with rod conversions.
Posted: Sun Nov 15, 2015 8:05 pm
by bazza3004
Thought the indian webs were very good and had a good tight pin . If thats true i would think they would handle a good bit of power as long as there trued up .
Posted: Sun Nov 15, 2015 9:50 pm
by gaz_powell
I have two standard 225 TS1`s running them plus a TS1 I built for a mate. - Chiselspeed built my two and the other built local - all done plenty of miles
I`m also running a pattern yam 115 in SIL webs.
Regards to BHP I couldn't comment
I would nt use anything but SIL webs with a suitable rod.
