Crownwheel
Posted: Sun Nov 08, 2015 3:35 pm
by Shipleystevep
Is it ok for there to be a bit of play on the crownwheel.?
Just stripped mine and found theres some play, is this normal
Thanks
Re: Crownwheel
Posted: Sun Nov 08, 2015 8:23 pm
by 10 inch Terror
A little bit is ok. If it's excessive you can buy shims that go under the spider to take up the extra play. MB sell the shims for this job. Sticky's book has all the information regarding clearances etc.
Re: Crownwheel
Posted: Sun Nov 08, 2015 11:08 pm
by Shipleystevep
Ok thanks,
Seems ok now its all back together and torqued up.
Just struck me as odd when I was putting it together again
Cheers steve
Re: Crownwheel
Posted: Tue Nov 10, 2015 5:24 pm
by shocky
10 inch Terror wrote:A little bit is ok. If it's excessive you can buy shims that go under the spider to take up the extra play. MB sell the shims for this job. Sticky's book has all the information regarding clearances etc.
They must be bloody thin I dont think anything that lifts the spider up (towards the kickstart shaft , and potentially lifting the top clutch plate out of the crown wheel ) is a good idea
I always hand grind mine to 0.10mm yes 1/10th of a mm :D
Re: Crownwheel
Posted: Tue Nov 10, 2015 7:02 pm
by 10 inch Terror
Yes they are very thin. We are talking 0.5mm etc. I've used them and they work perfectly well.
