Honda 205
Posted: Sat Nov 07, 2015 8:34 am
by whonatic
I've got a Honda 205 /30mm phbh/ Italian li150 gearing- 15/46
I've just fitted a jl curly having taken off a BGM clubman.
It now accelerates like a scalded cat up to 67/68 mph but that's it, which was the same as BGM clubman in terms of top end speed.
I know I need to dyno to see where it's making it's power, but is anyone running different front rear sprockets as a start for for me to increase the top end speed? Was expecting easily more than 70mph.
Paul
Re: Honda 205
Posted: Sat Nov 07, 2015 9:59 am
by rosscla
I think the JL3 peaks out around 7k revs and the curly might go 500 higher.
Check your gearing with Tony Cassiday's gearbox calculator
https://avantone.wordpress.com
Re: Honda 205
Posted: Sat Nov 07, 2015 10:13 am
by whonatic
Nice one cheers
Re: Honda 205
Posted: Sat Nov 07, 2015 11:10 am
by mick1
rosscla wrote:I think the JL3 peaks out around 7k revs and the curly might go 500 higher.
Just had a quick look at a gearbox calculator and with the gearing used it shows 68 mph at 7k rev's so everything looks about right. the final drive is around 5.2 so using a 16T front and going to 4.9 may be the solution. This will take it to 73 at the same 7K revs
Re: Honda 205
Posted: Sat Nov 07, 2015 2:12 pm
by gerryjunior
my cast iron 240 was topping out at 70 with a jl3 , i fitted a very old pm i had to see it it would change , and it was way better through the gears and about 5 mph top end, i have since bought a franspeed race and it fly's ,, jl3 now fitted to my old cast iron 200 and its fine ,,horses for courses i guess. i had a gori on my race rapido 200 and it would rev far better than the jl3,,
Re: Honda 205
Posted: Sat Nov 07, 2015 8:48 pm
by whonatic
Cheers People!
I was thinking if I can take it down to something like 4.9 approx, via a sprocket change, that would be good - and more cost effective than yet another pipe!
Re: Honda 205
Posted: Sun Nov 08, 2015 11:19 am
by stew
Has the barrel been tuned as I would think that would give you a better idea of what it would pull
Re: Honda 205
Posted: Sun Nov 08, 2015 12:38 pm
by Shipleystevep
I have a 16/46 li150 set up on a mugello 186 with clubman and it pulls fine.
Re: Honda 205
Posted: Mon Nov 09, 2015 1:30 pm
by corrado
stew wrote:Has the barrel been tuned as I would think that would give you a better idea of what it would pull
Yes that's a big factor and why you need to key in the various rpm factors that the gearbox visualiser asks for.
My Mugello is pulling 4.7 but my Imola wouldn't pull 5.0.
Re: Honda 205
Posted: Mon Nov 09, 2015 8:08 pm
by whonatic
The barrel has been tuned by a top bloke in Liverpool ( Mark Stevens if anyone knows him ) and it's been together for about 6 years.
I'm changing the gearing 16t front sprocket this weekend so it should be 4.9 rather than 5.22
